Eae pessoal blz!!!!
Estou vendendo meu cd pioneer 7900bt, completinho...
Supertuner (AM/FM Radio)
Supertuner Supertuner IIID
24-Station/6-Button (18FM/6AM) Presets Yes
BSM (Best Stations Memory) Yes
Local Station Setting Selectable (4-Step)
Satellite Radio Capability
XM Radio Ready Yes (GEX-P920XM Required)
Sirius Radio Ready Yes (SIR-PNR2 Required)
CD Player
1-bit D/A Converter Yes (8fs/16-bit)
CD-R/CD-RW Compatible Yes
AGC (Automatic Gain Control) Yes
Disc Title Memory Yes
Disc List Yes
Track Title List Yes
CD Text CD Text
BMX Digital Enhancement Yes
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 99
Max File # per Disc 999
Multisession Disc Play Yes
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9, 10
WMA Bit Rate 48~384kbps, VBR
AAC Format iTunes AAC
AAC Bit Rate 16~320kbps
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.2, 2.3, 2.4; WMA; iTunes AAC
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
Tag Display On/Off Yes
List Search File and Folder
Bluetooth Capability
Bluetooth Capable Built-in
Hands-Free Profile (HFP) Yes
Audio Streaming Profile (A2DP) Yes
Audio Control Profile (AVRCP) Yes
iPod Control Capability
iPod Control Capability "iBus" Direct Control (CD-I200 Required)
Additional System Expandability
IP-Bus System Control Yes
USB Control Capability Yes (CD-UB100 Required)
Multi-CD Control Yes
DVD Control Yes
TV Tuner Control Yes
Display Output Yes
Built-in Auxiliary Input Built-in (Rear)
Optional (IP-Bus) Auxilary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features
Face Type Flap Face
Motorization Auto Slide Motorized
Display Type Blue Organic EL (OEL)
Dot Matrix OEL Size 160x48 Pixels
Screensaver Movies 1
Multi-Language English, French, Spanish
Spectrum Analyzers Yes
Button (Key) Illumination All-Blue
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer EEQ (7-band Graphic)
Equalizer Presets 5
User Equalizer Settings 2
Loudness 3 Mode
Electronic Balance/Fader Yes
Source Level Adjuster (SLA) Yes
Crossover Network Two-Way Crossover
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
Subwoofer Direct Control Key Yes
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (4V), 100 ohm
General Features
Volume Control Rotary Commander
Operation Mode Rotary Commander
Remote Control 10-Key Card
Wired Remote Input Yes
Operation Beep Tone Yes
Cellular Mute Yes
Detachable Face Security Yes
Face Case (Included) Yes
qq dúvida estou à disposição
Valor: 310,00
Telefone ou E-mail: 1154821122
[FINALIZADO] [VENDO] - cd pioneer 7900bt
- Registrado em: Sábado 04 2006f Novembro 2006 11:17:40 PM
Opa, obrigado, mas no momento só venda mesmoaew brown, tenhu um dvd cyber inteirao! novinhu vo anunciar aki por 500. tem interesse na troka e volta uns 150? abraços
abraço!!!!
eae Caducevb....blz!?
Este aparelho tem saída para controle remoto por cabo?
Qual o motivo da venda?
Estou de olho no aparelho, vamos conversando.
Grande Amauri!!!eae Caducevb....blz!?
Vamos lá, em relação ao controle remoto por cabo, não sei te falar com exatidão se ele tem
isso, seria como se fosse na disqueteira? E estou vendendo pq estou precisando levantar uma
grana com urgencia, pra sanar umas continhas de começo de ano... qq novidade estamos aí
abraços!!!!
- Marco Túlio
- Ano de fabricação: 2016
Voce tem ele desde novo? qual a data de fabricação do mesmo?
Tenho em vista outra compra, se não der certo entro em contato com voce.
Então, peguei esse aparelho faz 1 mes, era de um senhor, e está novo, tanto q o microfone do bluetooth estava lacrado na embalagem original e nunca tinha sido usado, ele só tem o detalhe do botão mesmo, normal dos pioneer q costuma descascar, de resto funcionando tudo perfeitamente, só não vou saber te informar a data agora, pois o aparelho está isntalado no meu carro ainda, qq novidade estamos aí!!!Voce tem ele desde novo? qual a data de fabricação do mesmo?
abraço!!!
Opa blz!!!Troca num DVD Pioneer 7380AV sem voltas?
qual o estado do aparelho? quanto tempo de uso??
se tiver umas fotos, me manda por favor...
